tacho oil seal
wayno
tacho oil seal
#1 PostAuthor: wayno » Mon Dec 14, 2009 5:26 pm
how the hell do you fit a new one??? seems too tight
phil churchett
#2 PostAuthor: phil churchett » Mon Dec 14, 2009 6:36 pm
They are tight, ensure you have got all of the old seal out.
wayno
#3 PostAuthor: wayno » Mon Dec 14, 2009 7:24 pm
yes, got all of the old one out, only bare metal left
coldsummer
#4 PostAuthor: coldsummer » Mon Dec 14, 2009 7:44 pm
Try heating up the housing with a hair drier and apply a small amount of oil on the outer face of the new seal. Not sure if this is correct but it worked a treat for me when I replaced my fork seals. Also make sure you haven't damaged the housing when you removed the old seal. Good luck :wink:
wayno
#5 PostAuthor: wayno » Mon Dec 14, 2009 8:31 pm
think i may have found the reason its so tight, looking around for a complete unit and found this http://www.americanclassix.com/parts/new13/IMG_0154.jpg
which is what was fitted to the bike, and i bought a new seal from zpower which i presume is to fit this https://www.z-power.co.uk/merchantmanag ... p?pID=1134 dont know which is the correct for a z1000
phil churchett
#6 PostAuthor: phil churchett » Mon Dec 14, 2009 9:20 pm
Seal should be the same.
#7 PostAuthor: kev edwards » Wed Dec 16, 2009 9:33 am
the first one is the type they were made with,
Users browsing this forum: Google [Bot] and 28 guests
