Lads in Z land has any one got any 650 bits like a manual or seat in good nick,front master cylinder and splitter,speedo,anything else you can think off.
Os front engine mount plate.
Regards Ted
650 bits
Got a H***es manual on PDF, files about 27mb but can lob on a sharing site for you to download if any good?
Failing that can print one off and post but will have to ask a bit to cover paper, ink and postage?
Notice you're in Cleethorpes, not been down that way in ages, lived in Skeggy for a couple of years a while back,
You know you're getting old when you stop laughing at nasal hair trimmer adverts and start thinking, hmmmm.... you know, that looks useful!
I have a few bits, put aside from my current rebuild. Front master cyl triangular shape, top cover damaged on it tho and actual resevoir minor chamfer on one corner. A good used genuine piston for front caliper as well. Airbox with screw on top cover, the previous owner has enlarged the holes to the carbs slightly! plus a lot of engine bits in good order. US cam cover.
