Side Stand Length
KZCol
Side Stand Length
#1 PostAuthor: KZCol » Wed Dec 16, 2009 10:52 am
Could somebody please tell me the correct length of the sidestand fitted to a GPZ1100 B2?
I'm trying to figure out if it's been replaced with a shorter one or the bracket that is welded to the frame is bent.
Col.
Robw
#2 PostAuthor: Robw » Wed Dec 16, 2009 12:29 pm
Col, if you can wait I will get you the measurement tonight when I get back home.
Rob
KZCol
#3 PostAuthor: KZCol » Wed Dec 16, 2009 1:33 pm
Sure, no rush Rob.
Robw
#4 PostAuthor: Robw » Wed Dec 16, 2009 7:32 pm
Col, the sidestand is 29cm in length, when I was building my Zed I found that there are at least 2 different types of stand for these models. One looks like the stand type of stand with 1 spring, the one which fits mine has a 3 spring setup.
Rob
#5 PostAuthor: Al » Wed Dec 16, 2009 7:58 pm
Is it this type?
Robw
#6 PostAuthor: Robw » Wed Dec 16, 2009 8:27 pm
Thats the one I have on mine, the other type was not wide enough across the yoke to fit on the side stand lug.
Rob
PAULJAC47
#7 PostAuthor: PAULJAC47 » Wed Dec 16, 2009 9:20 pm
These type of stands can go weak where the bracket joins frame as water can get into frame and rust from the inside f kept on sidestand or even tear the frame have a look underneath to see if any evidence of bending or tearing...Paul J..
KZCol
#8 PostAuthor: KZCol » Wed Dec 16, 2009 10:45 pm
Yep, that's the one I have. It measures 10 1/2" from pivot centre to the tip of the stand. I can't see any noticable signs of rot and it all seems to look okay. If you're stand is longer then it could be a case of finding the correct stand. It could probably do with being about 1 1/2" longer which would take it to about 300mm from the pivot centre to end.
Cheers for the help
Col.
#9 PostAuthor: Al » Wed Dec 16, 2009 11:02 pm
KZCol the pictures above are of a 1981 J1.
It measures 11 inches near as dammit is to swearing from pivot hole centre to the tip of the foot.
The bike has standard geometry, standard size wheels/ tyres and standard length rear shocks.
The 'step' (mounting bracket) is virtually parallel to the ground when the bike is upright.
This bracket had 'peeled' away from the bottom of the frame where it's welded below when i got it and i welded it back into place in what i believed was the correct position.
Hope this helps
KZCol
#10 PostAuthor: KZCol » Thu Dec 17, 2009 8:57 am
Thanks Al,
I'll have a look today and maybe have to start the grinding and welding process!!!!!
