fork dismanteling
C Martin
fork dismanteling
#1 PostAuthor: C Martin » Fri Jan 08, 2010 1:11 am
i am haveing trouble undoing the bolt in the bottom of the fork legs so i can seperate the legs from the stancions on my z650, i have tryed the broom handle trick but still wont budge, i am begining to think that somebody has put them together using threadlock, i was wondering if anybody has any other suggestions or the propper fork holding tool i could borrow. I have spent two afternoons trying to get them apart and took them to my local bike shop but they only had the tools for yamaha forks which we tryed but did not fit, thanks
Chris
london calling
#2 PostAuthor: london calling » Fri Jan 08, 2010 7:59 am
Chris,my local bike shop in Loughborough can do it for you.
Twiggers on Nottingham Road,TEL:01509 263967 and speak to Mark.
Jack
Rob Lafferty
#3 PostAuthor: Rob Lafferty » Fri Jan 08, 2010 8:38 am
Had the same problem.
Held the top of the forks in a vice - with rags to protect. Then wound the pressure up on the compressor and out they came using an airgun. Inner did not have a chace to spin.
Only problem is doing them up again. Need to find a tool of some form. May look to make something this afternoon.
Rob
ruffle
#4 PostAuthor: ruffle » Fri Jan 08, 2010 9:45 am
Corby Kawasaki? Not that far from you and normally helpful.
StephenW
Forks
#5 PostAuthor: StephenW » Fri Jan 08, 2010 12:38 pm
The Club hold and lend out specialist Kawasaki tools.
I used the fork leg socket and returned to Jerry when finished.
Give Jerry a call.
Stephen
Crofty
#6 PostAuthor: Crofty » Fri Jan 08, 2010 2:43 pm
Chris, I had same trouble with my 650 ones recently. In the end and a lot of trying, I used a large easyout on the end of a couple of long extensions and it was out in under a minute. I inspected the cylinder piston unit afterwards and does not seem to have done any damage, no marks. Jim
ps did you get m/c OK
#7 PostAuthor: paul doran » Sat Jan 09, 2010 7:52 pm
if You have access to a heat gun or small blow torch heat the area around the bolt not too hot but for about two minutes then give the bolt a quick turn and it should come loose
it has never failed Me yet
ash
#8 PostAuthor: ash » Sat Jan 09, 2010 8:47 pm
Better still put your legs in a tub of cement and see how you feel when being screwed lol :D
Good luck Chris
Ed Z1-R
#9 PostAuthor: Ed Z1-R » Sun Jan 10, 2010 6:02 pm
Make sure BROOM handle is fettled to fit an use an impacct driver +heat to dislodge stubborn fastener :wink:
Jumbo
#10 PostAuthor: Jumbo » Sun Jan 10, 2010 6:11 pm
I had the same problem when trying to overhaul the forks on my KH250 and ended up making the tool. Which I think is fairly close to a 12mm socket. This was discussed recently on here. It was mentioned before by "Pigford" about using one of those adjustable multi sockets that works by having sprung loaded pins inside.
LE to JOG on a z900
P.U.M.
steve.w
#11 PostAuthor: steve.w » Sun Jan 10, 2010 8:13 pm
hi mate broom shank never failed for me ps dont put heat on alloy its a waste off time ull melt it before u get it hot enough :idea:
#12 PostAuthor: paul doran » Sun Jan 10, 2010 8:43 pm
steve.w wrote:hi mate broom shank never failed for me ps dont put heat on alloy its a waste off time ull melt it before u get it hot enough :idea:
oh! contrare Steve I have used this method several time's without melting any alloy
steve.w
#13 PostAuthor: steve.w » Sun Jan 10, 2010 8:50 pm
well paul uve been lucky it takes a lot of heat to expand metal/alloy :)
#14 PostAuthor: paul doran » Sun Jan 10, 2010 9:06 pm
the problem with these fork legs is the bolt fuses with the alloy
by aiming the heat at the bolt rather than the fork leg usually does the job but care is needed
steve.w
#15 PostAuthor: steve.w » Sun Jan 10, 2010 9:20 pm
i agree that metal n alloy fuse but if u concentrate heat on bolt itll expand thus making it tighter :roll:
