Earth
brian 450
Earth
#1 PostAuthor: brian 450 » Tue Jan 12, 2010 4:01 pm
I have run a earth wire from battery to the frame, My question is would it be a good idea to run one to the engine as well ? as it prob won't be earthed as engine is painted and the frame is powder coated, or does the engine not need earthing? Building them and making bits is not a prob to me but wiring is a different story :evil: :evil: :evil:
#2 PostAuthor: chrisu » Tue Jan 12, 2010 4:08 pm
there is normally an earth from the right side of the engine (at the back just above the kickstart) that goes to the battery - big thick wire.......
brian 450
#3 PostAuthor: brian 450 » Tue Jan 12, 2010 4:10 pm
no not got one
#4 PostAuthor: Rich » Tue Jan 12, 2010 5:11 pm
You should have a return earth from the engine directly to the battery of an equal or bigger size than the starter cable. I use 16 mm2 welding cable, it's very flexible and rubber/silicone covered so it is not affected by heat.
#5 PostAuthor: chrisu » Tue Jan 12, 2010 5:59 pm
as Rich says - you WILL need one. most car part shops will stock them.
#6 PostAuthor: Ginger Bear » Tue Jan 12, 2010 6:09 pm
brian 450
#7 PostAuthor: brian 450 » Tue Jan 12, 2010 7:35 pm
Thanks for help, Just come in from the garage i have run a lead from batt to the frame and another one from batt to engine, also fitted the one from the loom to the batt so i think i am fully earthed now!!! :lol: :lol: Tomorrow i will make a lead for the starter motor.
