z power clock kit ignition metal bracket
PAULJAC47
#1 PostAuthor: PAULJAC47 » Wed Jan 13, 2010 5:56 pm
Hi all just spent a couple of hours assembing my z power clock kit,does anyone know how the gold u shaped metal bracket with the cut out for the lock is supposed to fit if you fit it as shown in the parts book you cant get it deep enough into the plastic idiot light housing without fear of breaking the housing or be able to fit top fixing nut,tried all the ways i can think of,then looked at my old z1b set and this bracket is not fitted and it seems to function fine? any ideas anyone....Paul J..
GEZ635
#2 PostAuthor: GEZ635 » Wed Jan 13, 2010 9:20 pm
Hi Paul. Ive had a few replica sets and found that the bracket that comes with the kit is wrong and you need an original one. Like you, I sat down trying to work it out and then looked at an original clock set and could see the difference. I might have one you can have. I will have a look tomorrow and if I have I will give it to PB on friday.
Gez
Padders
#3 PostAuthor: Padders » Wed Jan 13, 2010 9:39 pm
Hi Paul dito a set I about 4 weeks ago if you give Phil a call he will send the correct bracket they have them hung up on the wall so they remember to put them on the kits!!!!
PAULJAC47
#4 PostAuthor: PAULJAC47 » Thu Jan 14, 2010 5:31 pm
Thanks Lads i thought it was strange!!
Garn 1
#5 PostAuthor: Garn 1 » Thu Jan 14, 2010 5:45 pm
Paul, I recall, I had a problem with this ignition-switch bracket on a Z1/A/B and thought I had the wrong bracket (possibly off a Z900-A4). However, after fitting the black plastic washer with the semi circular groove to take raised key on the barrel, in under the plastic bezel ring, the bracket fitted.
Mine may have been a different problem, but worth a mention. It took me over an hour to sort!
RegardZ
PAULJAC47
#6 PostAuthor: PAULJAC47 » Tue Jan 19, 2010 7:21 pm
Phil at Z power has now sent me the correct bracket(last one he said) fitted dead easy clock now on,may be an issue with anyone thinking of buying a set of these repro clocks?
Users browsing this forum: Bing [Bot] and 84 guests
