tarozzi rearsets
tarozzi rearsets
Just been on the disco volante site, im after some rearsets for the ST. i know a few of you have them, but is it best to go for model specific or universal fitting ones? there's quite a price difference. if model specific, would the MK2 or J ones do the job as ST isn't listed. Mine is 1980. Thanks.
1979 Z1000ST
it does interfere slightly, let's say the kickstart travel is 180 degrees, at about 150 it hits the tarozzi's brake lever (it's soft and gets marked), nothing can fix this - have to live with it, I kick start ocassionally just to show off and to save the lever I do it with footpeg opened so about 90 degrees has to do, and it does fine
Redbeard, there is quite a difference, check RAASK website, they list MK2 and ST rearsets separately and they look way different, I had Raasks on my bike before and they worked OK but had rather agricultural look, ST back plates seem to be a bit nicer, at least you have an option if no joy with Tarozzis http://www.raask.se/ind-eng.htm (rearsets/pick model)
Users browsing this forum: Bing [Bot] and 86 guests
