Which ignition system
Big Fluff
#1 PostAuthor: Big Fluff » Mon Apr 16, 2007 7:49 am
The S&S Silver Saxon turbo I have is fitted with the Z1000A1 engine (1978) and is still on the original points system.
I would like to go over to some form of electronic ignition system but wondered what would fit off other Kawasaki models. I know that the Dyna 'S' system is fit & forget, and is exceedingly good value but am open to offers should anyone have spare pulsars & box to sell. As for the wiring it's no problem, I've been wiring bikes for 27 years.
Many thanks, Will
london calling
#2 PostAuthor: london calling » Mon Apr 16, 2007 3:35 pm
Speak to Jeff Saunders at Z1 Enterprises for the best deals on Dyna ignitions,coils,etc.
Just go the links section and hey presto :D
Jack
FER
Auld Heedyun
#3 PostAuthor: FER » Mon Apr 16, 2007 9:18 pm
If you use a Dyna 2000 system you can program adv/ret curves for turbo.Like Jack says use Z1 enterprises.
fer
Big Fluff
#4 PostAuthor: Big Fluff » Tue Apr 17, 2007 7:31 am
OK will do and thanks for the help.
BF
Jeff Saunders
#5 PostAuthor: Jeff Saunders » Tue Apr 17, 2007 1:21 pm
With a turbo motor you will need to run your ignition retarded around 10 degrees - this helps avoid detonation.
The Dyna 2000 is a nice unit - out of the box you have a selection of retard settings. But if you really want to play, Dyna provides a programming kit to allow very precise ignition curve settings. The other big plus is a built-in rev limiter - a very nice feature with a turbo bike.
On my turbo bike, I run either 8 or 12 degrees depending on air temperature. On very hot days I use the 12 degree setting, but on cooler days I run 8 degrees - very easy to change - just a selection knob on the unit.
dragracer1260
#6 PostAuthor: dragracer1260 » Mon Apr 23, 2007 10:21 am
Go for the Dyna 2000 mate
the 'S' is a good unit but for a turbo fit the 2000
as said above - retard - rev limiter - boost retard AND you can run 1ohm coils :twisted:
Nick
