z1b float level
z1b float level
can any one help me i have a z1b which keeps flooding i have changed float valves and seats i can borrow a tool to measure float height not fuel height but i dont know what it should be ??? thanks steve
- paul doran
Most Mikuni carbs are somewhere between 17 - 20mm float height
The Haynes don't say, they only recommend using level gauge.
I'd guesstimate 18mm with float bowl removed, measuring from bowl gasket face (carbs inverted) to bottom of float as it just touches valve.
float height
HI THERE
Z-POWERS BOOK SAYS 23MM FROM AS PIGFORD SAYS THE GASKET FACE CARBS UPSIDE DOWN
PHIL
PHIL
International Rep
International Rep
z1b float level
Thanks a lot guys i'll try that and see how it go's thanks
