O'ring on Z1000A2 clutch/sprocket casing
Surfdeneige
#1 PostAuthor: Surfdeneige » Mon Apr 16, 2007 9:24 pm
Replacing a broken clutch cable and found in amoungst a load of oil/grease a small 6mm(ish) o'ring.
Where is it from? Is it from the clutch cable housing locating/centering pin?
A ken fit like!
FER
Auld Heedyun
#2 PostAuthor: FER » Tue Apr 17, 2007 4:41 pm
Could it be an o ring from the chain when it was fitted ?
fer
Surfdeneige
#3 PostAuthor: Surfdeneige » Tue Apr 17, 2007 5:02 pm
I found from the parts book that there is a little o'ring that goes on the centering pin as I had suspected. (pt no. 670B1507) Apparently they are there to keep grease within the clutch cable opertaing mechanism.
A ken fit like!
