Carb set up for K & N's
Just bought a '77 Z900 fitted with K & N air filters, but it's not set up correctly.
Does anybody know what main jet size & needle setting would be needed.
Steve K
Oh' it's also running a 4 into 1 if that makes any difference
Steve K
Steve K, yeeh, +10% (so about 125/130) as a start point. This may err on the rich side, but better that then weak
As for the needles, these will effect 1/4 to 1/2 throttle mixture. Do mains first then start fine tuning with needles after mains are OK.
Some say the standard carbs are a pain to set up when mucking around with hi-flo filters
Personally I run Mikuni RS flatslides, as they're good to tune, relatively cheap and offer good performance upgrade. Good luck
In continuing with the carb theme, on the bank of carbs, I have two fuel inlet stubs that connect to the fuel tap, one for the left bank of carbs, the other for the right bank, then I also have two vacuum stubs, one on each bank again, (A) & (B) now (A) connects to the vacuum stub on the fuel tap, but where does (B) go?
