tail lamp bracket
tricky
tail lamp bracket
#1 PostAuthor: tricky » Fri Jan 29, 2010 11:12 am
Anyone have a good or reasonable condition, z1/a/b tail lamp bracket for sale?
Or know if there are there are repo ones available?
thanks, tricky.
steve f
#2 PostAuthor: steve f » Fri Jan 29, 2010 11:15 am
uk or usa as they are different
tricky
#3 PostAuthor: tricky » Fri Jan 29, 2010 2:36 pm
hi steve, the bike is a z1000 a2 from the u.s.a, i am fitting a z1 tank which i have, and fits ok, i also have a z1 tailpiece, which fits no problem, but i want to fit an earlier oval tail lamp, 1, i think its a better shape, 2, with the z1 tail piece the square lamp sticks out too far, my bike has a new genuine short rear fender, i checked part numbers to day and the z1 and z1000 a2 short fender has the same part number, so i thought the tail lampbracket would be easy, what is the difference between the uk and us versions?
thanks tricky
tlc
#4 PostAuthor: tlc » Fri Jan 29, 2010 4:43 pm
The uk lamp is positioned lower to compensate for different hole patterns between the guards. A us bracket will be easier to find!
