Engineering in South Wales
v70z650
#1 PostAuthor: v70z650 » Mon Feb 01, 2010 4:46 pm
Can anyone recommend a good place to get some small engineering work done as part of my z650 rebuild, around the South Wales region (I live in Bridgend and work in Cardiff).
Im fitting a GPz750 swingarm in a twin shock configuration. So I need:
- The z650 swing arm pivot holes reemed out (by 1mm)
- The GPz swing arm pivot sleave shortened slightly (approx 1mm each end)
- The unitrack mounts removed from the bottom of the swing arm
- Twin shock mounts fabricated and welded on to the swing arm
Im obviously looking for somewhere tried-n-tested, that is used to working on bikes / restorations etc. and can turn their hand to the various jobs that I need done.
Rob
- v70z650: [Gallery] [Project Page] -
steve bowdler
#2 PostAuthor: steve bowdler » Mon Feb 01, 2010 6:29 pm
There is a guy lives near Port Talbot who maybe able to help I know he does a lot of work for the trike shop in cardiff(whom you could try)
http://www.trikeshop.co.uk/contact_us.htm.
I have his number in work will dig it out in the morning.
