Z1r Front Master Cylinder disassembly
ruffle
#1 PostAuthor: ruffle » Wed Feb 03, 2010 11:55 am
Ummm.... anyone know how the Z1R front master cylinder comes apart?
There's a white(ish) plastic part (No 13 on the parts diagram called a piston liner 14008-1007) that has to come out before one can remove the dust cover and the piston seal gubbins.
Do you have to turn that part? prise it out? get all violent with a large hammer? :)
TIA
ted1r
post
#2 PostAuthor: ted1r » Wed Feb 03, 2010 12:44 pm
Small screwdriverjust lever it out carfully then you will see how easy the rest follows.
Ted
"Work this is why I did it"
KE250
KZ1200
Puch Maxi
Be careful with Pensions :e
and me ol Granada
KeithZ1R
#3 PostAuthor: KeithZ1R » Wed Feb 03, 2010 6:12 pm
Like Ted says small electricians screwdrive or something of that type carefully between the liner and the top off the housing to release the locating tang and ease it out however having said that if its working and pressurising then dont touch it cos if you bollox up the seals putting it back together the piston is no longer available so its game over its assembled with the seals at source they cant be removed unless somebody can tell me different of course :(
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
ruffle
#4 PostAuthor: ruffle » Wed Feb 03, 2010 6:36 pm
Thanks Keith - worth knowing the innards are NLA (I should have checked but I kind of assumed it would use the same seal as the other Kawasaki 5/8 cylinders :oops:)
Perhaps I'll revise how I'm dealing with it.
KeithZ1R
#5 PostAuthor: KeithZ1R » Wed Feb 03, 2010 6:48 pm
Hmm my parts info show that part only fitted to D1 D3 so there is somethin special about it :?:
Keith
:bop :gom
mistaken.
