not a zed but a kawasaki all the same ke100 help needed
marve114
#1 PostAuthor: marve114 » Sun Feb 07, 2010 3:27 pm
ok boys n gals i know you lot are very helpfull :bow
recently we got my girlfreind a ke100 to do a bit of green laneing got it cheap but it needed the mains doing easy enough
any way had it all striped down everything was loose like some one had been in there sump nut was finger tight :lol:
the mains were fuu bared so i replaced them had the big end checked for up and down play all was good but i had that dought in the back of my mind :!:
had it rebored also new small end so i would have some thing trouble free for her to ride off road
put it all back together reasonably easy
3 kicks shes running but the big end is f!"ked also guted :x
so left it for a couple of weeks as i was a little cheesed off got engine out striped it all out to get the crank out
now for the question
does any 1 know were i can get this rebuilt or a conrod kit put on ?
cheers
lee
FOZ1A
ke100
#2 PostAuthor: FOZ1A » Sun Feb 07, 2010 4:27 pm
Just doing the same to a ke125-sent my crank to SEP - it had seized, and they turned it round in 10 days-supplied new rod etc.
foz
marve114
#3 PostAuthor: marve114 » Sun Feb 07, 2010 4:50 pm
how much did they charge :?:
could you give me there details please :wink:
kas750
#4 PostAuthor: kas750 » Sun Feb 07, 2010 4:59 pm
grampian motors in liverpool are a decent firm also.They do all sorts of two stroke cranks at a good price.
phil churchett
Re: ke100
#5 PostAuthor: phil churchett » Sun Feb 07, 2010 5:02 pm
FOZ1A wrote:Just doing the same to a ke125-sent my crank to SEP - it had seized, and they turned it round in 10 days-supplied new rod etc.
foz
I've used SEP in the past too, with good results;
http://www.sep-kegworth.co.uk/
london calling
#6 PostAuthor: london calling » Sun Feb 07, 2010 5:45 pm
S.E.P. Kegworth - 39 Sideley Road
Kegworth, Derbyshire, DE74 2FJ
Telephone: 01509 673295
Fax: 01509 673244
Email: info@sep-kegworth.co.uk
Motor and Motorcycle Engineers
High Class Reconditioners
Jack
marve114
#7 PostAuthor: marve114 » Sun Feb 07, 2010 6:00 pm
thanks you lot will get onto them tomorrow
#8 PostAuthor: kev edwards » Sun Feb 07, 2010 6:36 pm
Dartford rebore might be able to do it. :)
