BS Number
brian 450
BS Number
#1 PostAuthor: brian 450 » Fri Feb 12, 2010 6:21 pm
Was the Bs number for replacement exhaust BS AU 193 If so was there any letters or numbers after that?
london calling
#2 PostAuthor: london calling » Fri Feb 12, 2010 6:29 pm
Think you've got it all there Brian.
I'm pretty sure that it doesn't apply anymore and for M.O.T. test,exhaust noise is at the tester's discretion :??
Just double check with your M.O.T. station or tester.
Can't see your ZED failing :wink:
Jack
#3 PostAuthor: Ginger Bear » Fri Feb 12, 2010 6:39 pm
You'll be fine Brian...... I never have any bother with my cut down D&D can.
#4 PostAuthor: Pigford » Fri Feb 12, 2010 8:11 pm
As long as it doesn't say "For Race Use Only" or "Not for Road Use" then (as Jack says) its down to the MOT testers ears :wink:
