GPZ1100
KZCol
GPZ1100
#1 PostAuthor: KZCol » Fri Feb 12, 2010 9:13 pm
I suppose this should really be in this section as it's a bit of work in progress. As some of you will have seen I've made a couple of bits for the bike over the past while. Well here's the bike.
Still got some small stuff to do to it, but got a problem with the clutch. Get all the correct movement through the lever but not sure if the plates are sticking together or not as it just jumps when I put it into gear.
Col.
brian 450
#2 PostAuthor: brian 450 » Fri Feb 12, 2010 9:40 pm
That is a very nice example mate. I wouldn't mind building a modded one when the trick Z 1000 is finished.
#3 PostAuthor: Al » Fri Feb 12, 2010 11:41 pm
The bike looks fantastic. Love it. After all the work ive done to mine it still doesnt look anywhere near as good as yours. Well done with the mods too.
Clutch; end float on the primary (input shaft) or hub and bearing arrangement.
Is there any play (end float) in the primary shaft?
If you remove the plates from the clutch what do you get (rattle wise)?
If the double row bearing behind the clutch is worn you can adjust the clutch statically all you like but dynamically it will not dis-engage properly.
There are two thrust shims behind the hub. One either side of the clutch drum (basket) bearing. Clatter in the clutch is caused by play here. Iv'e just tightened mine up with a little tapping in the right place if you see what i mean.
Last time i put the crank case halves together i used a very thick gasket sealer thats not designed for bikes. It had the effect of holding the crankcase halves apart enough for the caged needle roller on the left hand side of the primary shaft to have some lateral movement in it. This coupled with play in the double row bearing allowed the primary shaft to move in and out with the clutch push rod!!!!!!!
Are there any notches in the slots on the clutch centre hub or the outer basket??
If so you will need to dress them with a fine file.
Similarly are the (outward facing) tabs on the friction plates peened over??
The plain plates are stamped out i believe.
If you look at them very closely you will see that they have a 'coarse' and a 'smooth' side to the centre 'fins'
If you want full, fast and complete engagement fit with the smooth side facing in. For satisfactory dis-engagement fit with the smooth side facing out. Its marginal but together with other small things does make a difference.
Are you using up-rated clutch springs?
What are the friction plates like. Are they helical pattern friction pads or radial ones? (triangular or rhombus in appearance)
What oil are you using; 20/50....? Meaning; does it tend to be more noticeable when cold?????
KZCol
#4 PostAuthor: KZCol » Sat Feb 13, 2010 9:02 am
Thanks for the comments gents.
Al, you've given me plenty to check over. The last time I had the plates out I measured them all up and they were like new. I am still trying to remember if I did actually count them though. A previous owner had put 1/8" thick washers between the springs and bolts I reckoned because the springs were tired. I removed the washers and fitted a set of uprated springs. Bearing in mind the bike has been off the road for a few years and the previous owner hadn't ridden it. I do know the engine sounds sweet and there is no rattle from the clutch when running.
Col.
outlaw
#5 PostAuthor: outlaw » Sat Feb 13, 2010 7:42 pm
hi, when you say it jumps when put in gear, is that from cold as mine does as well, but if i let it warm up for 2-3 mins before putting in gear no problem ( it does not jump then )
john
KZCol
#6 PostAuthor: KZCol » Sat Feb 13, 2010 9:42 pm
Stripped the clutch down today. It would appear the plates were stuck together. Put it back together and ran it up and down the street a few times and seems alright. I'll need to get my hands on another cable though as the one on it isn't quite right.
marve114
#7 PostAuthor: marve114 » Sun Feb 14, 2010 10:19 pm
very tasty like all the mods on your bike there
Monk
#8 PostAuthor: Monk » Sun Feb 14, 2010 11:20 pm
That is really lovely, looks great......side panel badges ?
KZCol
#9 PostAuthor: KZCol » Mon Feb 15, 2010 8:35 am
Yep, no side panel badges. Bike never came with any and the only place I know of getting some are from Reproduction Decals. Think they are about $100. Got a couple of small things for it's mot first then see how money goes.
Col
jimmock
#10 PostAuthor: jimmock » Thu Feb 18, 2010 9:41 pm
Hi KZCol, your bike looks braw!!! (for the members south of the border BRAW is a scottish word for nice!!! )
Paintwork looks superb.
Jimmock.
Jimmock. :wnkr
I hate people I don't like !
Crofty
#11 PostAuthor: Crofty » Thu Feb 18, 2010 10:03 pm
'Mint or well tidy', as they say in York. Like the mods too.
jimmock
#12 PostAuthor: jimmock » Thu Feb 18, 2010 10:18 pm
Crofty wrote:'Mint or well tidy', as they say in York. Like the mods too.
"Mods" aren't they the guyz who ran about on scooters with big jackets. I think they were all in the RAF too ????
Jimmock.
Jimmock. :wnkr
Kwackman
#13 PostAuthor: Kwackman » Thu Feb 18, 2010 11:05 pm
That bike looks great.
As mentioned above, side panel badges would set it off IMHO.
But even so, very tasteful bike!
All the best with it.
2006 ZRX1200R
1982 Z400J project
ex owner of Z1100R
GXI 2752 are you out there?
Motomania
#14 PostAuthor: Motomania » Fri Feb 19, 2010 7:06 pm
That looks fantastic, I remember going to Bristol Kawasaki to see one when they first came out years ago - still a favourite
Regards, Tony
That GSX600F's rear light sticks up in the air like a Baboon's arse?!
KZCol
#15 PostAuthor: KZCol » Sat Feb 20, 2010 7:16 pm
Side panel badges are on the list but bike is sidelined for the moment. Now got a wee boy in the family as from Thursday morning so all attention has been re-directed!!!!
