Z1 baffles
Andy T
Z1 baffles
#1 PostAuthor: Andy T » Sun Feb 21, 2010 4:27 pm
Hi, my Z1-B has the original numbered pipes. The baffles are bolted in on the side as usual but don't have the North to South bar across the back to allow you to twist them loose. Do you know anyway I can get them out without causing damage?
Regards,
Andy
Steve S
#2 PostAuthor: Steve S » Sun Feb 21, 2010 6:27 pm
Hi Andy,mine havent got the bar either,if once you remove the bolt they will not move outwards using a gentle grip of some pliers i usually give them a gentle tap inwards first,this usually loosens them and with a gentle pull and twisting motion should come out.May be worth a spray with something first if they haven,t been out for ages.good luck :D
Davy Doherty
#3 PostAuthor: Davy Doherty » Sun Feb 21, 2010 11:13 pm
A wee drop of wd and use a thick feeler gague to try and free around it then the whack in and pull out!!
jimmock
#4 PostAuthor: jimmock » Mon Feb 22, 2010 3:54 pm
Hi Andy T.
I took my baffles out a few weeks ago, mine were the "pea shooter" type too.
Just unbolted them and wiggled them with pliers on the pipe protruding from the end. Out they came.
Jimmock.
Jimmock. :wnkr
I hate people I don't like !
Andy T
#5 PostAuthor: Andy T » Mon Feb 22, 2010 9:59 pm
Hi, many thanks for all your advice. I will give it a go at the weekend & keep you posted.
Regards,
Andy
