MKII starter clutch
ARCHIE
MKII starter clutch
#1 PostAuthor: ARCHIE » Sat Feb 27, 2010 10:04 pm
Does anyone know why i have to rebuild my starter clutch a second time in 12 months. I gave it the once over when i rebuilt the engine last year changing the springs etc everything looked fine. After that it worked ok for 6 to 8 months and now back to square one with the rumbling noise and catching rarly. Does this sound fimiliar to anyone.
Thanks Archie
Theres fashion and theres passion
FER
Auld Heedyun
#2 PostAuthor: FER » Sat Feb 27, 2010 11:35 pm
Check the starter gear , if this is worn where the clutch rollers run on it they will not engage properly .
fer
Hobbo
International Rep
BOLT
#3 PostAuthor: Hobbo » Sun Feb 28, 2010 7:46 am
GUYZZ
ALSO CHECK YOU PUT ENOUGH THREAD LOCK ON ROTOR BOLT AND THAT IT AINT WORKED LOOSE
PHIL
International Rep
