z1.z900,z1000 heads compatability??????
PAULJAC47
#1 PostAuthor: PAULJAC47 » Sat Mar 06, 2010 9:57 pm
Hi all ,after todays abortive MOT run i find myself in need of a good head for my Z1b.i know the a4 head will fit but is the z1000 a1,a2 the same as well,seem to think it is? Paul J....just a thought is is possible to have a cracked rev counter entry repaired perhaps sleeved or welded and rebored?
nigel bessant
Re: z1.z900,z1000 heads compatability??????
#2 PostAuthor: nigel bessant » Sat Mar 06, 2010 10:04 pm
PAULJAC47 wrote:Hi all ,after todays abortive MOT run i find myself in need of good head for my Z1b.i know the a4 head will fit but is the z1000 a1,a2 the same as well,seem to think it is? Paul J....just a thought is is possible to have a cracked rev counter entry repaired perhaps sleeved or welded and rebored?
Me too!
PAULJAC47
#3 PostAuthor: PAULJAC47 » Sat Mar 06, 2010 10:07 pm
Not the sort you mean Nigel :??
#4 PostAuthor: chrisu » Sun Mar 07, 2010 8:26 am
they will fit. big give away is the exhaust studs are bigger. on the Z1000 heads.
I'd have thought a good ally welder should be able to fix - any photos ?
PAULJAC47
#5 PostAuthor: PAULJAC47 » Sun Mar 07, 2010 9:02 am
Hi Chris ,the one fitted at the mo has the larger exhaust studs,gonna pull it to bits today and see the score,looks like it has split the tunnel,there are some bits of the cam spiral thread missing as well reckon they are in the sump! will pull that off as well and have a look,just goes to show what a small part failing can do,good job it went early and not at high speed! will try and get some pics,Cheers Paul J..
Big Fluff
#6 PostAuthor: Big Fluff » Mon Mar 08, 2010 6:49 pm
What about the combustion chamber diameter :?:
We all know that the 903cc bikes have a 66mm bore, and a combustion chamber diameter to match. But does the 1015cc head have a 70mm combustion chamber diameter.
It'd only lower the CR a marginal amount, but I thought it may be worth mentioning that's all. :roll:
#7 PostAuthor: chrisu » Mon Mar 08, 2010 7:08 pm
i'm not convinced they're fundamentally different but I'm sure mr debben will be along shortly to advise.
if not I'll measure them tomorrow and see...........
Padders
#8 PostAuthor: Padders » Mon Mar 08, 2010 8:06 pm
Paul,
If you speak to Dave at Weldspek I am sure he will be able to sort it for you.
