Ltd carbs
mikey
Ltd carbs
#1 PostAuthor: mikey » Sun Mar 07, 2010 12:45 pm
Where does the vaccum pipe go on a set of ltd carbs looked all
over them and all i can find is these two brass stubs which i assume are for the over flow pipes
#2 PostAuthor: kev edwards » Sun Mar 07, 2010 2:26 pm
Mikey Just looked at my brothers and they are the vac pipes , two go to the emmisions system thats connected to the rocker cover one to the fuel tap and the other has a rubber bung over it , we got shot of the rocker cover and put a Uk one on and put rubber bungs on the stubs.
paulstrees
carbs
#3 PostAuthor: paulstrees » Sun Mar 07, 2010 2:28 pm
If they are diaphram carbs the two brass outlets are vacuum take offs so one will feed your tap the other should have a rubber blank.
The outer two will be linked to the emission system
I do stand to be corrected though if someone knows different
paulstrees
carbs
#4 PostAuthor: paulstrees » Sun Mar 07, 2010 2:30 pm
Kev beat me to it!
mikey
#5 PostAuthor: mikey » Sun Mar 07, 2010 6:32 pm
Ok cheers guys thanks for your replies very helpful
