Leaking brake caliper seal
Have had problems with front brake caliper piston seal leaking. Replaced seal as piston seemed fine (stainless steel). Still leaked so ended up fitting new piston and another new seal, it still leaks, only a weep but enough to fail MOT, can't be the seal to piston so can only think that fluid is leaking around the back of the seal. Is it possible to use some sort of bonding/sealing agent to fix the seal into the caliper to prevent leaking around it? If so what should I use? Anyone had similar experience?
AKA John Roscoe. PUM #028
1975 Z1B, 1980 Yamaha 350LC
Hi john, have you ensured that the groove that the seal sits in is really clean?and are you fiiting dry or using brake fluid or red rubber grease on assembly?
Fitting with v light smear of red grease, groove is really clean so can't understand it, I must be going wrong somewhere?
Is it better to fit dry (sure makes the job more difficult getting the piston in) Should I try light smear of brake fluid on the seal before assembly. The leak is very slow, drip on floor noticed after winter lay up of approx 5 months, when in use it doesn't seem to manifest itself (or maybe because I clean the bike after every ride I'm wiping any tiny traces away?)
It's bugging me
It's bugging me
IF You look at some seals they are not flat on the surface that seals onto the pistons but are slightly shamfered! try rotating seal 180 degrees! Try It, hope it works Paul J...
