Valve Clearances
Kev1R
Valve Clearances
#1 PostAuthor: Kev1R » Thu Mar 18, 2010 8:58 pm
2 Questions
Assume bog standard (z1000) engine:
Over a period of time, speaking generally - Do valve clearances get bigger or smaller?
Do you get better results with valve clearances on the tight side or on the generous side?
Thanks for any thoughts on this
#2 PostAuthor: Pigford » Thu Mar 18, 2010 9:02 pm
Clearances should get tighter as the seat/valve face wears.
Aim slightly on the loose side.
PAULJAC47
#3 PostAuthor: PAULJAC47 » Thu Mar 18, 2010 9:03 pm
Smaller....... best to err on the side of the upper end of clearance recomendation if unsure...
