a little advice needed..................pretty please !!
69chris
#1 PostAuthor: 69chris » Mon Jun 13, 2011 6:47 pm
just after a few words of wisdom if poss guys :)
fitted the zrx front end into the z today and, suprisingly it all just bolted together :o
but iv got 2 questions..
1st is that iv got a gap under the standard zrx dust cover - the one thats sposed to shield the top bearing, is it just a case of making something suitable out of an old aerosol can top ?? or is that a total bodge :oops:
2nd thing is the top yoke comes down onto the steering lock lug on the frame....... i was going to just chop the lug off, not worried about using it as its usually locked if i leave it anywhere - is that ok or another bodge ?????
last thing, chain aligment....
its quite a bit off (as expected) but having a crude measure i think an offset zzr1100c sprocket would do the job - or ?????
thanks guys :)
#2 PostAuthor: chrisNI » Mon Jun 13, 2011 7:50 pm
Pics would help.
The less you can cut off the frame the better if you can modify the yoke - it would be better than cutting the lug off the frame in case you ever fall on hard times and have to sell it to a collector who wants to restore it....
What's the offset on the ZZR sprocket?
69chris
#3 PostAuthor: 69chris » Mon Jun 13, 2011 9:11 pm
thanks Chris,
i dont think theres anything i could do to the yoke to alter the problem without having to re-locate the ignition switch...
snug aint it :lol:
and heres my dust cap gap..... the top yoke isnt fully down - see above as to why :D .
the zzr sprocket is 24mm ish........
http://www.jtsprockets.com/52.0.html?&L ... id=1214&p=
#4 PostAuthor: chrisNI » Mon Jun 13, 2011 10:54 pm
What clocks you using?
That 24mm measurement includes the thickness of the sprocket most quote how much the face is offset.
Did you see the post about the gearing before the site went down on Friday?
69chris
#5 PostAuthor: 69chris » Mon Jun 13, 2011 11:11 pm
im now going to use the standard clocks as the bolted straight onto the rex yoke and fit snug up against the ignition switch,
i measured 24 (ish) mm out from the back of the sprocket and from what i could see it looked ok....................but it was getting dark so ill re-look again tomorrow,
no i missed the final post (post's?) on that thread and i cant remember what antone said now anyway, iv had a sleep since then :lol: :oops:
69chris
#6 PostAuthor: 69chris » Mon Jun 13, 2011 11:12 pm
69chris wrote:im now going to use the standard clocks as the bolted straight onto the rex yoke and fit snug up against the ignition switch,
no i missed the final post (post's?) on that thread and i cant remember what anyone said now anyway, iv had a sleep since then :lol: :oops:
firyembers
Custard Creem
#7 PostAuthor: firyembers » Mon Jun 13, 2011 11:20 pm
The zzr 1100c is the most offset 530 sprocket you can buy standard
above that needs to be a custom buy from Debben or the like
http://www.wemoto.com/bikes/Kawasaki/ZZ ... ket_Front/
Could you as i see it fettle make wider the stops to allow the yoke to sit deeper...
Life shouldn't be a journey to the grave with the intention of arriving safely in a well-preserved body, but rather to skid in sideways, cigar in one hand, beer in the other, body used up, totally worn-out and screaming, "WOO HOO, what a ride!"
69chris
#8 PostAuthor: 69chris » Mon Jun 13, 2011 11:34 pm
firyembers wrote:The zzr 1100c is the most offset 530 sprocket you can buy standard
i think ill see if i can beg/borrow an old zzr sprocket of someone and try it before i buy a new un, it'll at least give me a better idea of what offset i'll need,
i was just going to trim the rear part of the yoke but the ignition switch is the same depth as those lugs so i wouldnt be any further forward :??
i can see the grinder getting some action tomorrow :lol:
Robw
#9 PostAuthor: Robw » Tue Jun 14, 2011 11:46 am
Chris, I had an alloy steering yoke made so I cant help you with that area, but I used a ZX10 offset sprocket with a washer behind it and the chain lines up spot on.
To fit the swinging arm I used the Z1000 bolt and had a spacer made up so that it would fit inside the ZRX swinging arm tube, this meant I could still use the ZRX bearings. I found that the swinging arm did fit but ideally you had to remove the battery box as it slipped in easier if you went from the top (that sounds naughty). I have a note book with dimensions in for various things so I will have look.
I am away until wednesday, so I will let you know then.
Rob
steve.w
#10 PostAuthor: steve.w » Tue Jun 14, 2011 8:04 pm
hi mate u using a 530 chain? if so u want a gsxr750 front sprocket n if u take about 8mm off rear sprocket carrier .. chain will be in line .. steve
69chris
#11 PostAuthor: 69chris » Wed Jun 15, 2011 8:34 am
thanks guys, i'll have another poke around at it today :)
69chris
#12 PostAuthor: 69chris » Wed Jun 15, 2011 12:11 pm
please excuse the shocking photo (crap camera - im a brilliant snapper me :lol: ) but id appreciate another opinion please guys :)
close enough ?????
lomi
#13 PostAuthor: lomi » Wed Jun 15, 2011 7:20 pm
Really interesting this thread as i'm about to do a 1200 zrx swingarn conversion on mine, i had the z bushes machined out and 20mm bushes put in so i could use the zrx spindle. i used the z stem in the zrx yoke which seems to have worked a treat and my igniton fits straight on to the top yoke. i'm a long way off chain alingnment yet so can't really be of any help there.
firyembers
Custard Creem
#14 PostAuthor: firyembers » Thu Jun 16, 2011 1:31 am
Looks close to me
Mine is similar and have witness marks on the tyre where it rubs..
But i have noticed my chain is bent...longitudinally..
May explain the tingly ass i had when driving it back from Aberdeen at up to 150/160
Image[IMG]
Will be fitting a new chain tomorrow or Friday
But also i may add,members have suggested i check for wobble factor in wheel,sprocket etc..which i will be doing..
Since this is a or seems to be a common conversion then succesful members with no bother can also comment as to a safe clearance
kano
#15 PostAuthor: kano » Thu Jun 16, 2011 2:04 am
this is the only time you can say to your wife, "honey i need to buy a laser!"
i live free and ride in the states but i am British and bloody proud of it!
http://www.kz1000r.com/
Users browsing this forum: Bing [Bot] and 33 guests
