Pigford - Mk.II Sprinter (monologue)
#1 PostAuthor: Pigford » Tue Jun 14, 2011 6:03 pm
Started with this ropey old 1980 Z1000A4 (Mk.II)....
Stripped it, powder coating here & there, GPz forks, GSXR wheels & s/arm...
GPZ1100 head - new over sized valves & guides, gasflowed, APE idler gear conversion....
...and an Orient Express 1392cc big block (2nd hand off Rob Zed1015)..
Painted engine...
Rolling chassis with half a motor stuffed in it....
Got it finished & all bolted together. More or less as it is today....
Just need to get carbs tuned in & do a shakedown run - but been uber busy last little while :roll:
#2 PostAuthor: chrisNI » Tue Jun 14, 2011 11:30 pm
There's more here than there was the first time :D :D :D
Mark Stratton
#3 PostAuthor: Mark Stratton » Wed Jun 15, 2011 6:01 pm
Looking real good Pigford.
Can't wait to see the video of the first couple of runs :wink:
kawman736582
#4 PostAuthor: kawman736582 » Mon Jul 04, 2011 11:30 am
turned out good mark..
bart
#5 PostAuthor: bart » Mon Jul 04, 2011 2:02 pm
Looking mighty fine. :xbou
#6 PostAuthor: Pigford » Mon Jul 04, 2011 5:10 pm
Must admit - it's more or less ready bar the final sorting of getting it running right.... :!:
But life gets in the way sometimes and I have been side-tracked :roll:
.... wifey being made redundant, granddaughters 1st birthday, son & daughter borrowing money, busy at work..... :cry:
Might get a chance to look at it this weekend :twisted:
#7 PostAuthor: Ginger Bear » Mon Jul 04, 2011 9:15 pm
Keep at it Piggy............. You'll get there. :)
Sorry to hear about all the 'side issues' :?? :??
#8 PostAuthor: Pigford » Sun Jul 17, 2011 9:59 am
Well, Shock - Horror - Hold the front page (Mr Murdoch) :shock:
I spent an hour out in the garage with the Mk.II.
Didn't do hell of a lot (coz its raining) but I fitted a pair of "quick release" fuel line things to speed up carb setting......
Then I re-torqued the head after I ran it a few weeks back - and they needed a good 1/2 turn (30 ft/lb).
I then fitted some new Denso Iridium plugs and started the fooka up and ran it for a few minutes :!:
Theres still a weep from the front of the cam chain tunnel :cry: and shes running weak - need the choke on full and still don't smoke :wink:
If truth be told I'm not planning to run her this year to give me time to get her sorted for 2012 :roll:
#9 PostAuthor: Ginger Bear » Sun Jul 17, 2011 10:45 am
No point rushing these things Piggy......... Take your time & get it right I say.
Let me know if you need any 'Pit crew' for 2012 :up
#10 PostAuthor: Pigford » Sun Jul 17, 2011 11:18 am
Ginger Bear wrote:No point rushing these things Piggy......... Take your time & get it right I say.
May just take you up on that Bear :wink:
#11 PostAuthor: Ginger Bear » Sun Jul 17, 2011 11:22 am
Well that's that then......... 'Team Pig' may well have just been born. :shock:
#12 PostAuthor: Pigford » Sun Jul 17, 2011 2:31 pm
OINK :P
pertonpc
#13 PostAuthor: pertonpc » Sun Jul 17, 2011 6:35 pm
Nice work Mark :wink:
Are we going to see that beast at Santa Pod in 2012???
#14 PostAuthor: Pigford » Sat Mar 31, 2012 5:57 pm
Did a bit to the Sprinter today - gonna get stuck into it over Easter .......
Just need to get it running proper like :wink:
Is Vic There
#15 PostAuthor: Is Vic There » Sat Mar 31, 2012 10:35 pm
Loverly stuff, have you any picture of the 900 in the back ground, or a thread? Would'nt mind a read of would you have done to that!
