Number 4 not firing
kwaka
Number 4 not firing
#1 PostAuthor: kwaka » Tue Jun 21, 2011 7:12 am
G'day fellas, took the bike for a lap around the block the other day but number 4 cylinder wasn't firing. when it started it seemed ok but down the road it started to miss and then nothing at all. I checked fuel but that was ok, but when i removed the plug to check for spark there was a weak spark and then none.
Where should i check next?
PAULJAC47
#2 PostAuthor: PAULJAC47 » Tue Jun 21, 2011 7:18 am
Swap leads one and four over,if four fires then but not one,prob means its your ht lead or plug cap faulty..Cheers Paul J
kwaka
#3 PostAuthor: kwaka » Tue Jun 21, 2011 8:06 am
Thanks Paul, but if i swap leads over would it cause the firing order to be out?
Mark Tiller
#4 PostAuthor: Mark Tiller » Tue Jun 21, 2011 8:27 am
1-4 & 2-3 fire together, so it will run OK
Spark plugs are much more sensitive these days so might be worth looking there as well
07962421462
kwaka
#5 PostAuthor: kwaka » Tue Jun 21, 2011 9:31 am
OK thanks, i'll give it a go.
Users browsing this forum: Bing [Bot] and 47 guests
