A4 Caliper (pads)
A4 Caliper (pads)
#1 PostAuthor: Garry.L » Fri Jun 24, 2011 2:47 pm
How slack (or tight) should the pad be that sits in the floating plate on my A4 caliper?. The original pad was almost stuck solid and the new one is a VERY tight fit..... is this right?.
TIA.
PAULJAC47
#2 PostAuthor: PAULJAC47 » Fri Jun 24, 2011 3:29 pm
Hi on my A4 calipers you can push the pad out with thumb pressure! Cheers Paul J
#3 PostAuthor: Garry.L » Fri Jun 24, 2011 5:00 pm
PAULJAC47 wrote:Hi on my A4 calipers you can push the pad out with thumb pressure! Cheers Paul J
Cheers Paul....
I thought the pad should be tight-ish but still be able to slide in the plate without to much force.
Thanks again.
