GPZ 1100 unitrack
ac/dc
GPZ 1100 unitrack
#1 PostAuthor: ac/dc » Thu Jul 28, 2011 8:59 pm
does any body know some one that can either drill out and or re tap and insert an exhaust stud with the head on the bike
i have one stud missing that was replaced with a bolt but the thread has failed and the bolt has no grip
Any takers if your not to far away i could ride it any further i would van the bike possibly a good little earner for someone ?
#2 PostAuthor: z1bman » Thu Jul 28, 2011 10:14 pm
it is quite an easy job to do yourself if you have some mechanical knowledge just purchase a 8mm re coil kit from e bay + a long series drill bit drill out the existing thread with the re coil recommended drill size. then insert the coil with the special tool that come with the kit job done . kits are about £22 on e bay
