Had some stainless front brake caliper pistons made for my Z1000 MkII.
Only problem is that one of the heat shields that sits inside the piston was destroyed during the process.
(Managed to get the other one out by drilling a hole in the back of the old piston & tapping it out)
Has anyone got an old 42mm piston that still has the heatshield in place?
42mm Front Brake Caliper Heat Shield
