I have a US import J1 and have finally got hold of a good condition Euro spec J3 fuel tank. Being fairly clueless about Kawasakis I thought the swap would be straight forward but... The J3 tank is narrower than the J1 tank at the front end where it sits on the circular rubber mounts. Has anyone come across this issue before?
The solution seems to be to get the grinder out and trim back the metal frame posts that the rubbers sit on by about 5 mm each side.
Has anyone done this before or knows whether this "adaption" will allow the tank to sit properly?
Regards,
Martin
Differences between US J1 and European J3 fuel tanks
Thanks for the reply but the bike is definitely a J1 (says on the frame number) and I got the tank from Lomi who is selling J3 parts).
http://www.z1ownersclub.co.uk/forum/vie ... c&start=15
I will get some photos tonight.
Martin
Martin
- paul doran
gsxkat wrote:Thanks for the reply but the bike is definitely a J1 (says on the frame number) and I got the tank from Lomi who is selling J3 parts).
Martin
US spec J1 has a different tank to J3
- paul doran
Well, after a few minutes of thought and measuring in the garage last night I bit the bullet got the grinder out and trimmed the frame tank mounts back by 5 mm each side and the J3 tank fits. I had to use different rubber cushions (katana ones) but essentially it now fits and just needs the rear cushion fitted to line up correctly as well as the seat fittings.
http://i1143.photobucket.com/albums/n63 ... C_0094.jpg
The bike is generally all there (and works) but needs a major tidy up but has GPz A1 wheel, V & H 'zorst, Eddie seat, Goodridge, Pingel (not fitted yet), and had RS36's but will be replaced by EFE 36's. There is also a GPz 11 A1 lump with 1170 and flowed head to go in. In the long term it will get ungraded wheels and suspension but first of all I need to finish the Kat.
Thanks to all for the replies and suggestions.
Martin
Martin
- big green bus
