It's driving me nuts. The manual says fit the new piston then the outer dust seal. How the hell do you get the lip of the concertina dust seal into the groove on the caliper. Help before I mutilate and kill my bike.Hello Guest User,
Re sealing 1000j calipers. HEEEEEEELP
Any tips on fitting the fekkin outer dust seals to Kawafekkinsaki calipers.
It's driving me nuts. The manual says fit the new piston then the outer dust seal. How the hell do you get the lip of the concertina dust seal into the groove on the caliper. Help before I mutilate and kill my bike.- london calling
Steve Cooke
- ZedHead
seals
Just done that pain in the arse job it runs a close second to fitting carb rubbers my advice is a little silicone spray and remove all blunt instruments before you start.
I had also major problems getting the dust seals into the calipers on my J.
Firstly I cleaned everything perfectly and inserted both the seal and the dust cover into the groove in tha caliper body. Now comes the tricky part
I invited wifey for some quality time in the garage. Using the fingers of 3 hands we spread the mouth of the dust seal as wide as we could across the face of the caliper. Amazingly we were able to stretch it wider than the caliper bore and because we held it down flat against the face of the caliper it did not leave the caliper grooves. Then with the remaining hand popped the piston into the bore. Your really nneed three hand cause the mouth of the seal has to be stretched really wide all around
