Correct Bolt size?
uk kev
Correct Bolt size?
#1 PostAuthor: uk kev » Mon Aug 22, 2011 9:07 pm
Can someone tell me the correct bolt size and form for connecting the steering damper to the lower triple tree on te Z1 please
#2 PostAuthor: z1bman » Mon Aug 22, 2011 9:34 pm
bolt size is 8mm don't know the length think its about 45mm if you are going to use the mounting bracket on the frame on the right side of the bike be very careful as these are very weak + have a habit of breaking of if the steering damper is set too stiff
