indicator relay
indicator relay
does the power to the indicators travel throught the flasher relay before the switch or after the switch/ cannot get power at the bars.
Do the lights come on and dont flash
then the contacts have welded shut, or if the dont come on at all peel it open carefully a the bottom, it may well be the the bi-metal strip is stuck open they get a bit tired after a while. if your gentle you can "adjust it" so it touches and then it should be ok
..........or if you cant be arsed just get a new one
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
