Hi
I have just about got my carbs where they should be and just having one issue with them them that I seem to be having problems with.
Bike ticks over fine and certainly runs ok but when I go up through the box the revs don't drop. If I change gear at say 5000 revs then the revs stay at 5000 revs during the gear change.
I have checke for air leaks and everything seems ok apart from one of the sliders. No1 carb slider does'nt go all the way down. It seems to be a little tight and holds about 10mm from the bottom. If you put your finger on the top of the slider and give a little push then it will go down.
Could this be the problem with the revs? All of the other sliders are fine.
Chris
Carb Issues........... still
- Muddychris
Experience is something you don't get until just after you need it.
