main fuse keeps blown
limer
#1 PostAuthor: limer » Fri May 11, 2007 8:44 pm
wondering if anyone can help, have just put a new battery in my 1976 z1000, started it up and after about 5min, the main 20amp fuse blew, put another one in after checking the terminals of the battery to make sure nothing is touching, another 5min, 20amp fuse goes again, cant understand it all i did was to replace battery and its eating up fuses like nothing on earth, any advice welcome
may need a sparky if nothing works, does anyone no a sparky near the Fife area eg Dunfermline or around that area
DogsbolloxofZ1B
#2 PostAuthor: DogsbolloxofZ1B » Fri May 11, 2007 10:12 pm
Strange that this should occur after 5 mins..
Difficult to say what the problem is from here but I would start by fully charging the battery then disconnect the charging circuit at the sockets, run the bike and see if it still blows.
I'm assuming that just prior to the fuse blowing previously that you weren't inducing a short circuit by switching the headlamp on, indicating or even turning a corner etc..
limer
#3 PostAuthor: limer » Sat May 12, 2007 7:45 am
no their was nothing wrong at all with the bike, i forgot to mention, it is only when i go to about 3000 to 4000 revs, as soon as it reaches their the thing just blows, but if i just left it to idle it would probably sit their all day.
i am demented with the thing!!!
Big John
#4 PostAuthor: Big John » Sat May 12, 2007 7:59 am
Could be rectifier, check voltage across batterry terminals at idle and then at 3000 revs.
#5 PostAuthor: Pigford » Sat May 12, 2007 4:48 pm
Teah, gotta be reg/rect as it happens as revs rise & alternator output increases :idea:
steve bowdler
#6 PostAuthor: steve bowdler » Mon May 14, 2007 5:20 pm
hi been away for a few days mine was doing the same ,changed rectifier not had prob since.
limer
#7 PostAuthor: limer » Sun May 20, 2007 1:33 pm
ok guys, thanks for the help, will go and check it out
