13mm Under Bucket Shim Swap Shop. Now Under New Management.
#1 PostAuthor: Ginger Bear » Mon Sep 12, 2011 11:48 am
Most of you will be aware of the club's shim swap scheme, for the larger shims to fit all Zeds from the Z1 right through to the Z1000J.
This has not included the smaller 13mm shims, fitted to Z650's 750's GPz1100 Uni-Trak & the 1100R
That's all changed! I recently bought approx 200 13mm shims from Z1bman & have managed to persuade Jerry to stump up for them!
I am happy to run the Swap Shop for these smaller shims (Contact Jerry for the larger shims) & I propose to run it like this;
Send your old shims to me, in a Jiffy bag or something similar, along with a return label & a large letter stamp & a note saying what size replacements you need & your membership number. I'll then send you back the required shims.
This service will be free to paid up club members (I will check :wink: )
It will also be offered to forum only members, but will require a 'donation' of £1.00 per shim swapped. All donations will go to Phil's fund at the MNDA charity.
Taffus
#2 PostAuthor: Taffus » Mon Sep 12, 2011 11:59 am
Image "Shimple!"
#3 PostAuthor: z1bman » Mon Sep 12, 2011 12:31 pm
well done Steve great purchase by yourself on behalf of the club hope all members appreciate your good work
Padders
#4 PostAuthor: Padders » Mon Sep 12, 2011 12:31 pm
Nice one Steve
corpy
Under-bucket shims
#5 PostAuthor: corpy » Fri Oct 07, 2011 10:40 pm
As a forum-only member I would like to buy (or swap) a couple of 13mm under-bucket shims
I note that you are a ginger bear in the woods - do you have a post-code, please?
Thanks for the service.
#6 PostAuthor: Ginger Bear » Fri Oct 07, 2011 10:57 pm
Corpy, I Can swop your shims, no problem. F.O.C.to club members, £1.00 a shim swap otherwise.
Cheers GB.
jimmock
#7 PostAuthor: jimmock » Sat Oct 08, 2011 1:29 am
Well done Ginger!!!
"SHimmock"
Jimmock. :wnkr
I hate people I don't like !
corpy
Shims
#8 PostAuthor: corpy » Sat Oct 08, 2011 9:06 am
Thanks, GB.
After sorting out the hiccup with the head/barrel joint's o-rings, I will soon be sure of the shim thicknesses that I need.
What address do I send the old ones to?
Thanks again.
#9 PostAuthor: Ginger Bear » Sat Oct 08, 2011 9:41 am
Corpy, PM sent. :sou
#10 PostAuthor: paul doran » Fri Mar 15, 2013 4:07 pm
excellent move Steve
I do the shim swop thing over this side of the water but using My Own shim collection
KWACKERZ1
#11 PostAuthor: KWACKERZ1 » Fri Mar 15, 2013 4:47 pm
Brilliant that will be very useful.
Nice one gb
alansaxman
#12 PostAuthor: alansaxman » Sun Oct 06, 2013 4:07 pm
I would like to swap a couple of 13mm shims please, for two 2.35mm shims. Could you pm me your address and I will pop them in the post tomorrow with the money.
Many thanks.
Mark Tiller
#13 PostAuthor: Mark Tiller » Sun Oct 06, 2013 4:44 pm
Well done GB....even more of a reason to become a full member :up
07962421462
#14 PostAuthor: Ginger Bear » Sun Oct 06, 2013 5:48 pm
PM on it's way alansaxman. :)
#15 PostAuthor: Ginger Bear » Sun Mar 09, 2014 9:17 am
Just a quick update on the 'stock' situation. :roll:
I now, no longer have any 2.05 or 2.15 shims available. Plenty up at the fatter end of the scale, just seems everyone wants/needs the skinny stuff for these aging motors.
Perhaps we need to find someone that can offer a valve tipping service :?
