13mm Under Bucket Shim Swap Shop. Now Under New Management.
Crofty
#16 PostAuthor: Crofty » Sun Mar 23, 2014 8:47 am
Hi GB, not sure if there is anyone in the club that could offer that service. I had SEP Kegworth tip some valves for me. Hence there is an envelope on its way to you with at least on 2.15 shim in. I need stuff in the range of 2.65 to 2.80 now.
Crofty
#17 PostAuthor: Ginger Bear » Sun Mar 23, 2014 8:54 am
Crofty, many thanks for your kind donation, that's the second one this week. :shock: Adrian H has also sent me his significant stash, as he no longer needs them. :up
.......... I'm beginning to feel like a 'charity case' :rir
Crofty
#18 PostAuthor: Crofty » Sun Mar 23, 2014 10:43 am
Donation!!!
I need to swap for larger shims GB!!!! Just mentioned there are some smaller sizes in the ones I have posted including a 2.15, you should get them on Tuesday morning.
After having the tips done, I don't have anything close to try in to get a reading to work from, I have sent 16 shims in to get 16 back and go through the trial fit and measure process.
Crofty
#19 PostAuthor: Ginger Bear » Sun Mar 23, 2014 10:58 am
My mistake! :hys
I'll try and get your shims out the same day...... All 16 of em. :wink:
#20 PostAuthor: Ginger Bear » Mon Oct 17, 2016 3:53 pm
After some negotiating with Steve Parr & Karen this weekend, Karen has agreed to take over this scheme.
Please contact Karen (Muckmagnet) for your 13mm shims.
kz900B1
#21 PostAuthor: kz900B1 » Mon Oct 17, 2016 7:28 pm
Musht', be a schimackover :oops:
colinKZ900B1
#22 PostAuthor: Al » Mon Oct 17, 2016 9:00 pm
Thank you.
ChrisB
Re: 13mm Under Bucket Shim Swap Shop. Now Under New Management.
#23 PostAuthor: ChrisB » Wed Jun 07, 2017 2:19 pm
Hello, I have a 265 and a 245 and need a 250 and a 280 large shim please. Pm me the address and I'll pop mine in the post. Many thanks.
#24 PostAuthor: ZedHead » Wed Jun 07, 2017 4:49 pm
Nice one!
ChrisB
#25 PostAuthor: ChrisB » Thu Jun 08, 2017 3:37 pm
Could someone post muckmagnets address or message me. Desperate to get a couple of shims swapped. Alternatively I have a 245 and a 265 and need a 250 and 280 if anyone can help!
wheelysteve
#26 PostAuthor: wheelysteve » Thu Jun 08, 2017 7:59 pm
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
#27 PostAuthor: Ginger Bear » Fri Jun 09, 2017 4:10 pm
ChrisB wrote:Could someone post muckmagnets address or message me. Desperate to get a couple of shims swapped. Alternatively I have a 245 and a 265 and need a 250 and 280 if anyone can help!
memberlist.php?mode=viewprofile&u=4007
DavidZ1R
#28 PostAuthor: DavidZ1R » Fri Jun 23, 2017 4:52 pm
I have two large shims from my 1000a1, a 270 and a 275. I am after swapping for a 260 and a 265, who is doing the shims, is it Karen and Steve ?
Swirl
#29 PostAuthor: Swirl » Wed Sep 13, 2017 6:25 pm
Hi who is doing the shim exchange nowadays for the larger Z9 shims thanks Swirl
#30 PostAuthor: ADRIAN H » Wed Sep 13, 2017 7:03 pm
Swirl wrote:Hi who is doing the shim exchange nowadays for the larger Z9 shims thanks Swirl
Jerry - el presidente I believe.
Users browsing this forum: No registered users and 198 guests
