Hi Can anybody give me some advice
Ihave a Z1000 A1 and having a problem with fuel leaking from between the carbs(around the t,pes),the bike has been away carbs been stripped,cleaned new gaskets,fuel pipes ,overflow pipes new t.pes (replaced twice),but still leaks , thinking of replacing the tap seals and the drain screws
Gratefull for any advice
Cheers Dunc
FUEL LEAKS
