one piece head gasket
slappa13
#1 PostAuthor: slappa13 » Sat Sep 24, 2011 11:53 am
when using a one piece head gasket, do you still use o ring around camchain tunnel. thanks Neil
#2 PostAuthor: Rich » Sat Sep 24, 2011 7:27 pm
no fill the recess level with silicone, leave to go off then just smear both sides of the gasket around the tunnel to seal it.
Garn 1
#3 PostAuthor: Garn 1 » Sat Sep 24, 2011 8:37 pm
I have seen some people fill the o-seal groove with silicon, leave the silicon to go off, as Rich says, then, with a razor blade, cleverly trim off to make the surface flat.
RegardZ.
