Hi Guys
Having problems with leaking carbs on my Z1000 A1
Is there anyone in the south lincs area who i could contact
Cheers Dunc
LEAKING CARBS
Hi Dunc
If they are all leaking your petcock may not be shutting off properly - don't leave it parked in the prime position.
If it's just certain overflow pipes that are producing petrol then the float height and float valve needle/ seat needs checking / cleaning on that bowl.
Haynes manual is pretty good on this and you can produce a home made float hight tester with clear aquarium air hose and a connector for cheap money.
Cheers from Mark
Cheers from Mark
