Does anyone know if any of the GPZ750 unitrak bodywork is interchangable with the 1100.
I can understand the tank being diffent but good old K were quite adept at using common parts.
GPZ1100untrak bodywork = 750 ?
tail piece + front fender should be interchangeable (fuel tank no) side panels no) front fairing possibly? i think it is only the mounting bracket that is different. the 750 is mounted on the head stock + the 1100 is mounted on both sides of the frame the seat looks the same but the 750 is slightly shorter
