full throtle probs
zman
full throtle probs
#1 PostAuthor: zman » Thu Oct 20, 2011 11:30 am
I seam to have had the same prob for a while but not always shown up.
this only happens when throttle has been open for a min or two.The bike starts to splutter like its running out of fuel.
does not happen on full tank.Only when it gets to around the point of going on reserve .
Seamed like fuel prob but fuel flow on fuel tank is good.have also changed fuel tap[thanks eddi]
carbs have new jets but could there still be some sort of blockage that only sonic cleaning will solve. :?:
keep thoses wheels turning
Mark Tiller
#2 PostAuthor: Mark Tiller » Thu Oct 20, 2011 2:43 pm
float heights set wrong?
Vapour lock? drawing fuel fast from the tank causes a vacuum inhibiting the fuel flow
muck in the bottom of the tank?
07962421462
#3 PostAuthor: Pigford » Thu Oct 20, 2011 4:33 pm
I'd go with fuel flow - check tap filter/s & pipes ..... and filler cap vent :!:
#4 PostAuthor: Rich » Thu Oct 20, 2011 5:38 pm
Probably is running out of fuel if you are on prolonged full throttle, opening up the fuel galleries in the carbs will help as will fitting a bigger fuel tap. This is the main reason 29mm s/bores are much better than 28mm Mikunis.
To eliminate tank breather out of the equation undo the cap when it is doing it.
Garn 1
#5 PostAuthor: Garn 1 » Fri Oct 21, 2011 9:45 pm
What about water in fuel it does stay on the bottom!
Start a fresh, empty tank and refill with new petrol.
RegardZ
#6 PostAuthor: Rich » Sat Oct 22, 2011 7:35 am
Just drain the float bowls into a tin and see if there is water in it.
#7 PostAuthor: Pigford » Sat Oct 22, 2011 7:47 am
............... double check coils - connections & +12v supply when running :!:
andyb1962
#8 PostAuthor: andyb1962 » Sat Oct 22, 2011 8:42 am
my bike had this problem a year ago.
previous owner fitted a pingel fuel tap from the states. problem solved.
Andy :wink:
#9 PostAuthor: Al » Sat Oct 22, 2011 8:46 am
I drained the Z1r tank recently through the tap hole several times and found a piece of pliable newspaper the height and diameter of the fuel filter!!!
zman
#10 PostAuthor: zman » Sat Oct 22, 2011 9:13 am
Thanks for all your help.i will work the list till i fined problem.easiest first of course. :lol: :lol:
