1978 Z1R Carb Diagram
SP10mk11
#1 PostAuthor: SP10mk11 » Sat May 19, 2007 5:27 am
Hi does anyone have a parts diagram for the carbs on a 1978 Z1R that they cuold show me
Some time ago i bought a set of 28mm carbs (when i got the bike it had 26mms on it) these had no jets,bleed pipes floats etc
I have fitted Z1R size mains and pilots and changed the bleed pipes
Since fitting these the bike has always run too rich (sooty plugs)with a stutter just off idle.
I am now wondering if the carbs i have are from a Z900, which apparently have larger needle jets and needles.
Gary
bedlow1
#2 PostAuthor: bedlow1 » Sat May 19, 2007 6:33 am
here you are
1972 Z1 Euro Spec
1975 Z1B UK Bike
SP10mk11
#3 PostAuthor: SP10mk11 » Sat May 19, 2007 7:28 am
Ere! fanx for that..........I think lookin at that picture....i can see a difference.........my air screws are not in the same position, they are on the side like the ones in the picture but they more towards the middle of the carb body
Right thanks alot for that
I could send a picture of mine up for anyone to see
Gary
