Advice please
MCZ900
Advice please
#1 PostAuthor: MCZ900 » Fri Oct 21, 2011 5:53 pm
Just doing a few jobs on my new project and have brought a new LH side stator/ dynamo ally cover, old one came off ok, question is i have undone the 3 allen bolts inside to take off the electrical coil thing and it dont want to come out.
Help please
1973 Z1 and 1976 Z900
#2 PostAuthor: z1bman » Fri Oct 21, 2011 6:33 pm
the stator is quite a precision fit you have to try to get both sets of your fingers behind the stator + work you way round the stator a little at a time until it becomes loose
MCZ900
#3 PostAuthor: MCZ900 » Fri Oct 21, 2011 6:48 pm
Thanks i will have a play in the morning
Garn 1
#4 PostAuthor: Garn 1 » Fri Oct 21, 2011 9:42 pm
MCZ900, as Z1b Says, it's a precise fit!
Just hold it in a bowl of hot water (without getting any water inside the casing) it will just fall out.
RegardZ.
MCZ900
#5 PostAuthor: MCZ900 » Fri Oct 21, 2011 10:56 pm
I love this help section thanks i will have a go in the morning with the hot water
MCZ900
Hot Water
#6 PostAuthor: MCZ900 » Tue Oct 25, 2011 3:44 pm
The old hot water trick worked,
Thanks very much. :D :D :D
