slow
slow
My Z1000A2 starts easily, runs smoothly, ticks over smoothly,
you'd think theres nothing wrong with it but its always seemed slower than everybody elses, its got no kick in the pants feeling if you see what i mean.
Last week i got my old GS650 shafty motd and taxed and even that feels faster.
Everything as far as i can tell is set up right, any ideas anyone, supose it would be a good idea to put it on a dyno ?
- Ginger Bear
Pigford wrote:...................green ones are faster![]()
It could well be down to fuel/air in - vs - exhaust out![]()
What carbs, air filter, exhaust you got![]()
What was that re-ocurring problem you had with the Zed last year
Standard air box and filter, carbs, jets etc
Exhaust, 4 into 1 as pic but have to say baffle hole is pretty small
problem had was a misfire which was cured with new dyna s leads
- Mark Tiller
- Mark Tiller
Mark Tiller wrote:P.S.....whats the zorst? looks short? this can also have an effect
Its harris down pipes with a harris collector box, and i believe the end pice
is a piper or something, but yes the opening of the silencer is a bit restrictive
ill open it out and give it a go
