Z650 sight glass/master cylinder
redzee
#1 PostAuthor: redzee » Tue Nov 01, 2011 6:10 pm
Hi All,
My brother in law has just started the restoration of his Z650 F3 (1982). The master cylinder sight glass is cracked and weeping (hit by a stone!!) and he is looking for a reliable fix or replacement of the glass or even changing the whole unit if one is available from someone on here. Can anyone help please? I will get him to sign up and post some pics of the resto if I can.
By the way, he says it is a 'coffin' shaped master cylinder and the bike is an Italian import if that matters. A replacement seat base is also on the list (pattern or copy).
Cheers guys
redzee
Eight valve grunt.
Crofty
#2 PostAuthor: Crofty » Tue Nov 01, 2011 7:36 pm
Hi Redzee, try measuring the glass in the resevoir and see if it is the same as the oil sight glass in the clutch cover. Mine is the same, but the m/c I have is the oblong metal type. I think you can still buy the oil sight glass, the m/c ones were never a stock part
http://www.cmsnl.com/products/gauge-oil-level_52015004/
redzee
#3 PostAuthor: redzee » Fri Nov 04, 2011 6:22 pm
Crofty wrote:Hi Redzee, try measuring the glass in the resevoir and see if it is the same as the oil sight glass in the clutch cover. Mine is the same, but the m/c I have is the oblong metal type. I think you can still buy the oil sight glass, the m/c ones were never a stock part
Hey Crofty,
Nice one, measured the oil sight glass and it appears to be the same :D
Worth taking a punt and buying one to try at that price. Brother in law sends his thanks, much appreciated.
redzee
Eight valve grunt.
