Exhaust repairs.
irhobotolo
Exhaust repairs.
#1 PostAuthor: irhobotolo » Tue Nov 01, 2011 6:43 pm
One of the pipes on my KH500 seems to have developed some holes :??
One is right on the seam on the underside and there is a very paper thin section further along which will need careful sorting otherwise it will go into a hole.
Its difficult to find a decent replacement and the pipe is solid everywhere else with great chrome.
Any ideas greatly appreciated :D
jimmock
#2 PostAuthor: jimmock » Tue Nov 01, 2011 6:48 pm
Many years ago I got my pipes (standard system) on my Z1A repaired.
I told the guy I wanted stainless patches welded using stainless rods.
It worked out really well.
I got a good 3 years out of them, then I sold them to a guy from Peterborough.
Jimmock.
Jimmock. :wnkr
I hate people I don't like !
kas750
Re: Exhaust repairs.
#3 PostAuthor: kas750 » Tue Nov 01, 2011 7:25 pm
irhobotolo wrote:One of the pipes on my KH500 seems to have developed some holes :??
If its near the seam then they are scrap.Kh500 and h1 pipes are fairly common.I found a set of 3 at this last stafford show for a club member for 300 quid.
irhobotolo
#4 PostAuthor: irhobotolo » Tue Nov 01, 2011 7:39 pm
kas750 wrote:If its near the seam then they are scrap.Kh500 and h1 pipes are fairly common.I found a set of 3 at this last stafford show for a club member for 300 quid.
Its a shame because the pipe is mint with realy good chrome and no scrapes or dinks and the other two pipes are fine. I cant see me getting it through an MOT though with it leaking smoke from the underside. :oops:
jimmock
#5 PostAuthor: jimmock » Tue Nov 01, 2011 7:49 pm
Exhaust paste will be enough to get it MOT'd.
As long as it has NO LEAKS from the system.
Jimmock.
Jimmock. :wnkr
kas750
#6 PostAuthor: kas750 » Tue Nov 01, 2011 8:16 pm
If its just to get it tested and use while a good set turns up you can seal the hole with araldite.The 2t pipes run pretty cool so it holds up well.
PAULJAC47
#7 PostAuthor: PAULJAC47 » Thu Nov 03, 2011 4:33 pm
Steve, i have had some success witha poduct from Halfords,Plastic Padding Chemical Metal,i mixed some aluminium paint into it and it sets rock hard and is petrol and oil proof,i even sealed a sump on a car with it,it even looks ok with the ally paint in it and you can file and smooth it,give it a go,,Cheers Paul(i love Suzukis) J
KeithZ1R
#8 PostAuthor: KeithZ1R » Thu Nov 03, 2011 5:34 pm
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
jimmock
#9 PostAuthor: jimmock » Thu Nov 03, 2011 5:48 pm
Or what about a piece of "retro" SUPER BAZOOKA gum.
Chew it for an hour, then "mould" it over the holes in question. Once dry a quick paint with shiney silver paint.
Jobs a good 'un.
Jimmock.
Jimmock. :wnkr
irhobotolo
#10 PostAuthor: irhobotolo » Thu Nov 03, 2011 6:08 pm
Thanks Guys.
I am now resigned to using filler on it and will get the pipe off at the weekend and sort it. Should be okay as like Adrian says the pipes dont get that hot and its well away from the header.
Do they still sell that super Bazooka gum then ? Havent seen that for years ? Wasnt it pink ?
tlc
#11 PostAuthor: tlc » Thu Nov 03, 2011 6:22 pm
Aaaaaaah, Bazooka Joe. What a guy :D
jimmock
#12 PostAuthor: jimmock » Thu Nov 03, 2011 7:54 pm
Thats the very one.
My jaws are aching thinking about it!!!
Jimmock.
Jimmock. :wnkr
#13 PostAuthor: Pigford » Thu Nov 03, 2011 7:58 pm
......I've got bad memories of an incident at junior school (many years ago) which involved a wooden chair, a hot cast iron radiator and some Pink BazookaB/ Gum :??
#14 PostAuthor: Ginger Bear » Fri Nov 04, 2011 12:05 am
Come on Piggy....................... Tell us more! :lan
Users browsing this forum: No registered users and 114 guests
