z1r/mk2 spacer
tricky
z1r/mk2 spacer
#1 PostAuthor: tricky » Thu Nov 10, 2011 1:39 pm
hello all, does anyone have for sale a brake side rear wheel spacer, to fit a z1r or mk2 pt number 42032-080, heres hoping, bye for now tricky
#2 PostAuthor: z1bman » Thu Nov 10, 2011 2:26 pm
phil denton does them in stainless steel
kawasaki z1r
Rear wheel spacer (brake side)
Stainless steel replacement
Stainless steel for a lifetimes service
Zero corrosion
Replaces hard to find part/s
Code: 42032-080
Price: £19.35
We know Kawasaki owners and restorers like their machines to look as original as possible. With this in mind all our Kawasaki stainless steel replacement components retain the same appearance as the original item unless otherwise stated. Unlike the original item they will never rust and are less likely to become damaged. We can even at a small extra charge vapour blast these items to look identical to the original factory zinc plated finish!
Contact Information
For more information, or place an order, please use our online contact form, or contact us at:
Mail: Unit 4, Station Yard, Station Road, Llanrwst, North Wales, LL26 0EH, UK
Phone:01492 641345
E-mail:
tricky
#3 PostAuthor: tricky » Fri Nov 11, 2011 6:33 pm
thanks mate, thought stainless would have been expensive, but not too badly priced.
Baz Swailes
#4 PostAuthor: Baz Swailes » Mon Nov 14, 2011 12:29 pm
I could turn you up one in alloy if you want.
I am in Durham so can't be that far from you.
BAZ
tricky
#5 PostAuthor: tricky » Mon Nov 14, 2011 2:04 pm
thanks for the offer baz, i have sourced the parts i need through john browse on saturday, thanks again, tricky.
