Hi, what carbs would you recommend to replace the fuel injection
on a GPZ1100 B2?
Thinking carbs off another bike, Z`s, Gixxers etc.. as opposed to
something more expensive like smoothbores.
Any advice on this would be most appreciated.
Allan
Where fuels rush in.
- london calling
- london calling
Allan,although the bike will run on non-Kawasaki 34mm CV Mikuni carbs they probably won't work as well throughout the rev range,tickover as well,etc.
A set of early GSXR 750 slabslide model,Mikuni flatslides are a good set to go for.You can strip 'em dowm and get the reducer collar bored out to 33mm and away you go.Plus with the slide carbs you can run individual filters no worries,whereas the CV's need an air-box to work properly.
Jack
- big green bus
