gpz1100 b
when turning the engine over, the starter is struggling,
slowing down to a stop.
-can this be fixed?
i also taken the head off,
but when putting it back on trying to make sure it stays at TDC on the crank end it moves slightly.
and when checking the cam shafts that the in and exh are pointing opposite directions and 44 teeth apart.
the arrows should be parallel to the rocker block.
is this right, or any tips to help me get it back running again.
thanks
engine probs
Starter motor struggling - could be either:
Dirty or loose connections from battery/solenoid/earth
Tired starter motor - brushes worn
Duff battery
If you haven't removed the spark plugs - this'll help to stop the crank turning - its usually due to compression build-up at TDC
Make sure pistons (1 & 4) are at TDC. Ensure the EX cam is pointing out & mark is level withtop of head, then count teeth - don't panic if IN cam is not quit level with head
Duff battery
